Where to get aftermarket caster kits
From Mackay
many moons ago there use to be a aftermarket caster kit that was similar to an XF falcon one, for those of you that dont konw what the falcon one looks like it has an excentric bolt and 2 fixed brackets that are on the Xmember with a slotted hole in them so that when you spin the bolt it pushes the lower control arm in or out.
So if anyone knows where you can get these kits from please let me know
Thanks Michael
Posted on: 2005/9/8 15:38
Re: Where to get aftermarket caster kits
From Radelaide, South Australia
Go to www.datsport.com, think they may be able to help ya out...
Posted on: 2005/9/8 15:41
Boost.. boost.. BOOST!!! Gotta love Lag...
* 76 coupe, twin 40mm a12, project...
* 79 ute ca18det, track/street...
* 84 FJ45 landcruiser project...
* 88 D21 navara 4x4, sr20de vvt daily...
From Newscastle, Australia
Noltec do the strut tops for the 1200:-
Noltec 1200 catalogue
Posted on: 2005/9/8 23:38
Dont die wondering.....
From Mackay
Converted.
I've got the tops off Kev Rowley I'm after the other end I want to move the bottom of the wheel in and out
Posted on: 2005/9/8 23:57
From Canberra
Sounds like you want to change the camber from the above quote, for that you need to rose joint the lower control arms to make them adjustable. The caster rods move the front wheels forward and back. If thats what you want to do, then try finding some castor rods out of an LJ torana, they are stronger, longer and have good adjustment. Small mods necessary to fit them but its pretty easy with lots of castor angle achieveable.
Posted on: 2005/9/9 1:22
From sydney australia
yes,do you want to change the static camber of the wheel,or the castor?if you want to change the camber,this can be achieved with adjustable castor arms,the more castor,the more the wheel will 'fall over' when it's turned.this will mean less wear on the tyre inner edge,increasing the life of the tyre.my sunny has 1.5 degrees static negative,with 6 degrees castor.when you turn the wheel,it automatically starts picking up more negative camber,which sits the tyre flatter to the road,when you take body roll into account.
if you still want to do it with a camber pin,most
suspension places will be able to supply a kit.
or you could get the crossmember redrilled.
Posted on: 2005/9/9 5:20
You can :-
a) redrill a hole in the x-member
b) get a longer lower control arm from a stanza, skyline. or cut it and weld in plates to give it more length
c) fabricate your own lower control arm which is adjustable
Posted on: 2005/9/9 7:55
From Mackay
I think I've confused myself I've got R31 radius rods ADJ , S13 lower control arms non ADJ and ADJ tops to move the top left and right ....I also want to move the lower control arm in and out {left - right} (not sure if thats caster or camber???) If there is no such thing that you can buy off the shelf its no drama as I will make it
Posted on: 2005/9/9 11:58
