Re: Audio Problemo
If the radio has noise or is picking up noise - the amp will just amplify it.
Turn the gain down
played with the gain after reading the instructions to work out which dial it was ... turned it down a 1/4 and she's now all good. can now crank up the tunes and here them clearly over the webers
thanks guys
Posted on: 2005/9/16 11:41
Re: Audio Problemo
From Perth, Australia
This is a bit of a long shot, but you might want to try replacing the spark leads. I seriously doubt anyone has them any moe, but if they are the old, old carbon type, then they'll cause noise with new head units. Also, if the condenser on the dizzy if faulty, it can cause hassles and finally, believe it or not, if the car is simply out of tune, it can cause it. But like I said, they are in the "Unlikely" section. But what can it hurt to check ??? That way you might be able to turn the gain back up
Posted on: 2005/9/19 14:52
1974 120Y Coupe
40 thou overbored A14
32/36 DGV Weber
5 Speed Gearbox
New Interior (in the making)
My website
Re: Audio Problemo
From Colac, Vic, Oz
Yes there is alot of things to check like leads & earth straps to check. l have allways found one or more items isn't upto standard stoping static going to my cd player or CB radio (am or uhf). Thanks for the comments in this forum. Keep Cruzin folks. Bruns
Posted on: 2005/9/20 15:11
Dato's NEVER die just loved forever and ever (and by the girls too). Including my nine toys
« 1 2 (3)
