Manifold
From Bridgetown, Barbados. W.I
tryin to make up an efi manifold for my Turbo charged A12. i dont have access to the standard efi system nor a manifold for twin sidedrafts. So i have came up with the idea to use a modified standard one, but would like your input on this setup.
plenum will be welded to the two inlets....
Posted on: 2005/9/19 0:34
Life's better SIDEWAYS!!
Re: Manifold
From WA
make sure you clean up the inside on the "old" manifold while you're there.
but yes, great thinking.
you can get camira cold-start injector bosses welded to the injector holes you've drilled to take a press fit injector for a low cost alternative.
cheapest is sometimes the easiet and best way to go about things.
Posted on: 2005/9/19 6:10
Re: Manifold
From Newcastle (NSW)
Were does one get camira cold-start injector bosses from ?? Or are you talking about cutting up an old camira manifold ?
Posted on: 2005/9/19 10:26
Re: Manifold
camira injector bosses are srew in units i think.... just weld them in though....
camiras come with enough problems. Dont spread them to the 1200's
Posted on: 2005/9/19 10:28
Re: Manifold
From Perth W.A
And i'm not too sure on how many camira's are floating around barbados.....
Posted on: 2005/9/19 11:45
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Manifold
whats a camira?? who made them?
Posted on: 2005/9/19 12:09
Re: Manifold
Holden Camira, 1982 - 1989 (i think) in series: JB, JD & JE
Engine: 4 cyl. SOHC
Capacity: 1600cc
Power: 64 - 85 kw (in respecting order)
Transmission: 4/5 spd. man.; 3 spd. Auto
Thats the JB 1982 - 1984
Thats the JD 1984 - 1987
Thats the JE 1987 - 1989
Probably one of the most fugliest cars produced!
But alas, good for mutating to make our beloved Datsun's go better and more reliably...
Dave
Posted on: 2005/9/19 12:52
Re: Manifold
dont have any of those here
Posted on: 2005/9/20 0:44
