Browsing this Thread:
1 Anonymous Users
Re: heed help on various vacuum hose |
hi
thanks for the feedback
i just re-check those hose actually previously i check wrongly. so now i notice the choke-pull-off have a dedicated hose (like in the pic) and the throttle pull-off also same.
my problem is.. my choke 'activate' slow when i start the engine the choke actually work after about 10 second the engine start.. dono if it is related to vacuum
and i just found out another thing that there is one vacuum port (split into 2) that is after the carburetor and before the manifold.
i saw it connected to a 'T' join, one connect back to itself (where it split into 2) and another one connect to the air box.. (after the air-filter before the carb)
is this vac leak? why need to connect to that place? i just curious.. :(
hope someone can help..
Posted on: 2005/9/20 4:49
