Re: a12 GX inlet/exhaust gasket
From Bunbury Western Australia
the rest of the engine will be the same as a standard A12 engine. The GX engine has oval intake ports and two studs at the top of each pair of intake runners, the bottom end is the same except the crank is balanced and runs 10.0:1 compresion ratio. I would suggest you try http://www.swmotorsport.com/enginegskt.htm
for all your parts as he seems rather cheap for prices
Posted on: 2005/9/21 7:09
Subject Poster Date
     a12 GX inlet/exhaust gasket PIGDOG 2005/9/21 2:34
       Re: a12 GX inlet/exhaust gasket blofly 2005/9/21 7:09
         Re: a12 GX inlet/exhaust gasket 1200rallycar 2005/9/22 5:29
           Re: a12 GX inlet/exhaust gasket A14force 2005/9/22 10:59
             Re: a12 GX inlet/exhaust gasket B120dat 2005/9/22 11:46
               Re: a12 GX inlet/exhaust gasket boofhead 2005/9/22 12:32
                 Re: a12 GX inlet/exhaust gasket dattoman_1000 2005/9/22 12:59
