#1 removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 7:08
Hey all,
just trying to switch instrument clusters to fit the coupe cluster into my perfect stock sedan dash - but I'm stuck as the bloody wiper switch won't come off!!
the headlight one just fell off pretty much but the wiper one is on tight - do I just pull harder on it or is there a trick to it? it's just the knob on the end that's giving me grief btw - I know to undo the actual switch itself.
Also question 2 - when I retrofit the coupe cluster in - is the black wire on the back of the tacho the one to wire to the coil?
Cheers
Ash
#2 Re: removing light/wiper switches & factory tacho Q
Tyrie Posted on: 2005/9/21 7:17
knobs are secured the same way as a lightbulb (push and turn to remove)
also about the cluster change, does the loom have to be changed too? I put the original back in my ute (strip speedo) and the switches/lights did all the wrong things.
#3 Re: removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 7:22
crap! I hope the looms are interchangable - I don't have a coupe loom!
edit: the wiring FAQ states that the loom in non-tacho cars has the loop for the factory tacho - so in theory it's the same loom?
anyone confirm?
this has obviously answered my tacho question
#4 Re: removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 8:05
Was there a round speedo dash that didn't have a tacho? cause my loom doesn't appear to have the right gear in it. Also as Tyrie said - the large round connector appears to have totally different pinouts.
I'll probably have to put it all back & get an aftermarket tacho now goddamnit!
#5 Re: removing light/wiper switches & factory tacho Q
phunkdoktaspok Posted on: 2005/9/21 8:06
The looms contain the same wires, but you will need to swap some pins around in the round plug that goes into the dash.
From memory I think Dattodude had a picture on swapping the pins on one of his websites
#6 Re: removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 8:12
Awesome! *goes looking for Dattodude's website*
Are the tacho loop wires definately there? I couldn't find them.
#7 Re: removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 8:20
Alright, found the diagram -->Click me
but I'm a tad confused about the tacho wiring still - I assume the loop isn't there & you have to put it in?
#8 Re: removing light/wiper switches & factory tacho Q
phunkdoktaspok Posted on: 2005/9/21 8:38
Loop is definately there. Its the black/white wire from your key to the coil. From factory it originally runs directly behind where the tacho will be located and it will have coloured tape over it.
#9 Re: removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 9:31
hrm, my loom might be a freak.
There's two wires there alright, but they are red/white and green/blue - also they have round plugs not the flat spade connectors of the tacho. multimeter time I thinks... edit: they aren't plugged together either - I believe the ones I'm looking for should be plugged together?
Also a couple of the wires in the round plug are different too but I think they might just be discoloured as other than that they are in the right spots.
#10 Re: removing light/wiper switches & factory tacho Q
Ash Posted on: 2005/9/21 9:52
the red/white in the tacho location goes to the connector on the ignition barrel adjacent to the black/white
the green/blue goes through the firewall to a box with 3 prongs on it next to the balast resistor
Is this the right animal with the wrong colours/plugs?
PS: this is an Auto shell - do they have different looms?
