Re: hi guys just wanting to know wat turbos u run
From Mudgee NSW Australia
I'm running a chipped factory ecu. Supposedly good for 15psi but I need to sort out my ignition first. Last time it was on the dyno it was breaking down above 11 psi.
Matty close your plug gap to around 0.7-0.8mm
I had the same problem with stock ignition with my old gt25 a cheap fix made it good for at least 15psi
1200rally car I have read that article it was in a zoom magazine. I can buy that turbo from Greenline motorsports for $2500 delivered from japan. Im happy with what I have for the moment so cant justify spending any more for a while
Posted on: 2005/9/12 23:14
If In doubt run more BOOST
From Brisbane
Im running a T28 BB turbo, with chipped factory ECU pushing 13psi through it. Just got it dynoed the other day and got 213.8rwhp
Posted on: 2005/9/13 0:38
From sutho shire
450hp GT25 turbo with external should be good for around 300-330rwhp few more mods helping it get there,
Posted on: 2005/9/13 7:29
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From australia
bump
Posted on: 2005/9/23 1:48
From Little Rock, AR
I'm running the S15 T28 (ball-bearing) turbine on my SR20. It put down 285 rwhp with this turbine boosting at 1.15 bar. If I had a choice, I'd go for the GT2871R, they're about $1000 US and on my motor would crank out up to about 375-390 rwhp. I'd rather put that one on my 240SX (Silvia) than the Datsun though.
I'm going to go with a top mount T3/T04 setup instead due to availability of parts and clearance issues in the future....no more of this T2 flange stuff on my Datsun, bring out the big guns!
Posted on: 2005/9/23 2:45
From Melbourne, Australia
RBH32 Daihatsu charade turbo on my a12 but im changing it to a supercharged a12 at the moment.
Posted on: 2005/9/23 4:48
« 1 (2)
