Installing and A15?
Quite a regular
From Adeliade, Australia
Ok here the scenario! I own a datsun Sunny sedan (a12), he owns a vanette (a15)! Just a few questions;
Will the engine mounts from the a12 cater for the a15?
Will the sunny (a12 sump) fit on the a15?
Will my new clutch on the a12, fit on the a15?
Will my extractors from the a12, bolt up to the a15?
I have asked these questions before and have recieved a variety of responses. Does anyone know any definite answers or has completed the same conversion?
Posted on: 2005/9/30 0:56
Re: Installing an A15?
You own an Australian Sunny [B310] Right? I can only assume since we aren't priveledged to know what country you are in.
Perhaps you could fill in that detail in your profile.
The engine mount brackets that are bolted to your A12 block will fit onto the A15 block. This means that you can then use your original engine mounts.
The A12 sump will fit to the A15 block, but don't do it for the reasons given the last time a answered this question for you.
The clutch will fit, but think about using the lighter A12 flywheel too.
The extractors will fit the A15 cylinder head, but no guarantees that the stock A15 inlet manifold will fit back on. The only way to find out is to give it a try. The A12 inlet manifold will not fit onto the A15 head.
Posted on: 2005/9/30 1:16
Love your Datsun.
Treat it well.
Re: Installing and A15?
Quite a regular
Cool, so the a12 flywheel can be used on the a15!
Will the vanette sump fit into the sunny?
Im not sure what type of sunny it is! Its a sedan and thats all I know! Il post up some pictures shortly!
Posted on: 2005/9/30 2:43
Since you have added your location details, then yes, you have a B310 car. The Sunny name was used on the small Datsun models in various markets throughout the world since late 1966, but only on the B310 version in Australia
Posted on: 2005/9/30 2:49
Love your Datsun.
Treat it well.
Quite a regular
This is my datto and everyday car! Needs a power increase! Currently running an a12, extractors, exhaust, chrome air filter, rebuilt carby with larger jets! Will be selling the motor soon!
Posted on: 2005/9/30 6:08
From Townsville NQ
looks like a tidy example!
Though that sill looks a little warped or something
Posted on: 2005/9/30 9:43
hi..
i think everything fit
except the exhaust header..
and throttle cable (not long enough)
Posted on: 2005/9/30 10:54
Quite a regular
Hopefully the extractors on my a12 will clear the a15 inlet manifold?????
Warped?????? Must be the photo! Ran out side and checked and its perferctly normal!
Posted on: 2005/9/30 13:01
Quite a regular
From South-Africa Pretoria
Hi,just want to know, what is a extractor??
Posted on: 2005/10/1 0:28
A fabricated tube exhaust manifold. They are better known in some countries as 'Headers'Open in new window
Posted on: 2005/10/1 0:34
Love your Datsun.
Treat it well.
