#1 what happened to my hazard lights? (double signal)
nismo18 Posted on: 2005/10/3 20:53
i accidentally pushed the left side signal when my hazard lights (double signal) is on. now my hazard light only illuminates on the right side and seems that the left side is all dead...darn..what happened? how to fix that?
my ride is a b310 btw...thanks for your replies in advance.
#2 Re: what happened to my hazard lights? (double signal)
B210sleeper Posted on: 2005/10/3 21:16
maybe the blinker relay is bad?
#3 Re: what happened to my hazard lights? (double signal)
nismo18 Posted on: 2005/10/4 6:06
ah i see...where is this part located? isit hard to find the spares?
#4 Re: what happened to my hazard lights? (double signal)
B210sleeper Posted on: 2005/10/4 18:18
It's a regular lamp blinker, they still make them. they're located under the dash near the steering wheel, they are sometimes looking like little metal cans.
#5 Re: what happened to my hazard lights? (double signal)
nismo18 Posted on: 2005/10/5 0:32
thanks a bunch for your help...will try to look for that part and replace it...jus in case of emergency its really useful.
btw, my reverse lights are dead too...i think the reverse light switch is spoilt. sigh, is it hard to find this part and replace it? where is the part located?
#6 Re: what happened to my hazard lights? (double signal)
B210sleeper Posted on: 2005/10/5 1:06
Hmm, maybe you blew a fuse, since i think all the lights are on 1 fuse. The reverse light switch is on the transmission body if it's a manual.
#7 Re: what happened to my hazard lights? (double signal)
nismo18 Posted on: 2005/10/5 4:04
damn...that means i need to open up the transmission body if my switch is spoilt...that sounds really tedious...if thats the case... i think i'll jus leave the reverse light dead. hopefully the fuse is blown instead...havent checked the fuse yet. neway thanks again for you help.
