can a ca20 5sp fit a ca18???
Hi can a ca 20 5sp fit a ca18 and is it much larger than the standard ca18 box.
is there any advantages or disadvantages of these boxes?
which clutch to use?
Posted on: 2005/10/5 12:34
Re: can a ca20 5sp fit a ca18???
From Sydney
Yes it will. It is actually shorter than the CA18 box. It would be fine in a 1200. I ran one in a bluebird running 10psi for 2 years without any probs so the light 1200 will be fine. advantage would be the shifter would be around 50mm forward.
Matt
Posted on: 2005/10/5 13:04
From California
datt-matt responds to the lazy button
Posted on: 2005/10/5 17:20
Thanks for that info, know i can buy that auto frount cut and use the ca20 box. all i need now is a clutch and fly wheel....
Posted on: 2005/10/6 9:18
