Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#61
Re: Give us your dream Engine and Gearbox Datto combo !
oan878
Posted on: 2005/10/4 12:52
GO THE ROTA!!!
I'm going the 13b turbo option too. after i finish my ca18det ute i'm cutting out the tunnel in my 2 door sedan and putting in a 13b bridge port turbo with a T70 on it. The best of both worlds ported and turboed!! sound realy fat!! everyone always asks what about getting it enginered? I will look in to it but who cares there is always someone out there who will do it for the rite price....
#62
AFRacer
Posted on: 2005/10/5 0:55
My SR20DET 12000 is just about to my dream car status level with the exception of the body/paint, a little bit more suspension work, and a stronger diff. I love everything about it except not being able to get traction and no A/C.
Can't argue with 115+ mph quarter mile trap speeds without getting traction, quieter exhaust than stock, and then still getting 33+ miles per gallon on the highway!! A few other things I would like to do is BIG fender flares and FAT tires all the way around, roll cage, a 5 or 6 speed cross-mission and dual plate clutch, rack and pinion steering, and Ultralight 4 pot brakes up front and 2 pots in the back on huge disks.
#63
Tommo1200
Posted on: 2005/10/5 6:52
13B with a a turbonerics "big thumper" turbo with a jagg rear end, with a five speed air shift lenco
#64
nz_datsun_1200
Posted on: 2005/10/5 9:58
with my 72 1200 sedan id like to fit a nissan quad cam alloy v8 with twin turbos custom and a g-force 5spd gearbox and a good old ford 9" lsd diff with disc brake held in place by a 4link rear end.
with my 82 sgx sunny sedan i plan on fitting a redtop jdm sr20det mostley standard apart from arp rod & head bolts je pistons apex cams & after market inlet and exhust dump pipe with t28 turbo. gearbox 6spd s15 diff skyline wagon diff with nismo lsd! will go hard
#65
Widget
Posted on: 2005/10/5 11:09
dat will be a toyota MR2 twincam supercharged with a cressida 1fge gearbox. Stock motor pushes bout 135kw = 180bhp. dat will do the 1/4 mile in high to mid 11sec. with some work done on the motor can break 9sec easy!!!
#66
trb012
Posted on: 2005/10/5 11:23
For the strip id have to go another 1200 ute 20B big turbo diff tubs ect would be very nice but for the track id love to build a 1600 to the same spec as the nizpro one fullhouse z18 turbo big brakes suspesion ect looks like a sports sedan and goes like one too
#67
lowlyf
Posted on: 2005/10/5 11:34
i dont know if some one has already put it in but a fuel injected 2l pinto with seiara 5sp or a EJ25 with suby undercarriage 4WD and 6spd
#68
Boostin
Posted on: 2005/10/5 15:36
2 door 1200 sedan, 200kw rwd e15et, any 5 speed that wont break.. holding flat 11sec passes in street trim...
#69
DATT-MATT
Posted on: 2005/10/5 17:05
Mine would be a ford GT40 replica rolling on 18" x 9" and 18" x 12" wheels with brakes to fill them. It would be powered by a 20B running a supercharger and a quite-ish exhaust putting out around 600+HP. I'm sure i'm not dreaming??? if you were handy with a welder i guess you could do it for around $50K..
Matt
#70
Grunterhunter
Posted on: 2005/10/6 4:24
Nice idea Matt!!! so you get a chassis from a ford GT40 and put a datto body on it..... with some massive flares to cover the extra track width and stretch it to cover the wheelbase.
SICK!!!! I was thinking more along the lines of a SWB landy chassis with a 350 chev, Xtra large mud terrains, and bolt a ute shell to it with a 10" lift for a bit of mini-monster truck action You can view topic.
