« 1 (2)
Re: head lights
dat5_al wrote:
hey guys i just got a 1200 Ute 2 months ago and already had to replace the headlight fuse twice and it is stuck on high beam. even when i have it on low beam it doesn't work unless u hold it all the way back and it goes down to low beam when i use the left indicator I'm stublled. Anyone had a problem similar to this
BTW its an 82 model
From your description, it looks like you have problems with the blinker/ dip switch. Pretty serious problems if it changes beam when you go for left indicator, & you can't get low beam most of the time.
If possible, pop the steering wheel off & have a look inside the switch to see if you can find any excessive wear or busted bits. I suspect a replacement switch assembly will help, but check it out first.
Posted on: 2005/10/13 13:05
Love your Datsun.
Treat it well.
« 1 (2)
