(1) 2 3 »
Water temperature sensor stuck in block!
From SE Melbourne
Evening (or morning) Datsun lovers
I'm up to the next challenge in the whole engine strip/build.
Removal of the temperature sensor from the block.
I got the threaded sleeve off (it was really tight though) - now the sensor wont budge - a set of vice grips and a bunch of rust penetrant over a few days have not worked it loose.
Threaded sleeve coming off
Rust penetrant spray
I've run out of options, so thought I would draw on the collective experience of others....what do you think?
Posted on: 2005/10/17 12:56
Mildman, Datsunless
Re: Water temperature sensor stuck in block!
From Sydney, Australia
Trip to the wreckers or repco for a replacement...
Then go about smashing it angrily, until it falls out.
I've not seen this problem before. Can you get at it from inside where the thermostat goes? Maybe a little leverage there will make it let go.
None of my repair books talk about it's replacement/removal.
Hopefully someone can suggest a method better than my destructive removal technique.
Chris
Posted on: 2005/10/17 13:47
From Melbourne, Australia
ive had the problem before but straining my brain to remember how we got it out, definately destroyed it to get it out but still cant remember how, you can get at it from thermostat area but cant remember if that was the solution
Posted on: 2005/10/17 13:50
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Ipswich,QLD
I had the same problem .pull the pin out on the sender end with a pair of pliers ,Then drill it out .A new sender will cost about 17 $ from repco .
Posted on: 2005/10/17 14:03
Sadly, once it's stuck good & proper, then all too often you have to make a simple choice
Destroy the head to save the sender,.... or
Destroy the sender in trying to remove it, but save the head.
New replacement senders are not all that expensive & if you fit the new one with a little bit of a suitable anti sieze compound, & run only coolant, [not water] it should never stick again.
Posted on: 2005/10/17 14:08
Love your Datsun.
Treat it well.
From SE Melbourne
Sounds like the sad truth had been layed upon me brother!
I'll give it some loving with some vice grips, drill and whatever else tickles my fancy with no regard for the sender itself....
When you gotta go you gotta go.
(I'll hold off until tomorrow Oz time) in case anyone else thinks of a brilliant strategy.
Thanks again all
Posted on: 2005/10/17 14:41
Mildman, Datsunless
From Bunbury Western Australia
what if you heat the sensor area up with a heat gun and use a copper drift to gently tap it through inside the coolant passage then it should come out the thermostat housing opening?
Posted on: 2005/10/17 15:06
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From Burbank, CA
Mine did that too...
what i did was carefully use locking pliers ( vice grips or whatever ) and spray lube on the sender and wiggle and twist carefully, and mine came out intact and I used it again.
Posted on: 2005/10/17 22:27
|||\ 81 KPB310 /|||
From SE Melbourne
Err...what's a copper drift?
I'm not familiar with that type of tool.
I assume it's some sort of tube?
Posted on: 2005/10/18 0:35
Mildman, Datsunless
yeah mate a copper drift is a piece of solid copper rod that is used to direct force to one area the size of the diameter of the drift, like you could possibly knock it into the temp sensor reccess.... I think, but possibly the sensor will not go through that way, I can't remember on mine but I think the heat gun idea could get the metal to expand a tad and that could all be enough to loosen it enough to come out, plus when the metal area expands, the penetrating lubricant may find it's way to the concerning area and free it up
Posted on: 2005/10/18 2:51
(1) 2 3 »
