Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Mini Me now with 181rwkw
prodat
Posted on: 2005/10/20 2:42
After some mid week tuning this week @ Autotech in Canberra the 1200 ute is now putting out 181rwkw at a fairly mild 12psi.
We are taking it out to Wakefield tomorrow (hopefully the weather holds up) to get some times on it. Should be fun!
#2
Re: Mini Me now with 181rwkw
Mr_Turbo
Posted on: 2005/10/20 10:17
181rwkw at a fairly mild 12psi. nice effort in the lil ute.. wats the specs of the motor to be puttin out that much? wat ratio diff centre to?
#4
converted
Posted on: 2005/10/21 0:14
Wakefield times let me guess........mid 1.15's any other takers????
your main prob will be getting power down.
#5
blofly
Posted on: 2005/10/21 1:37
jeeeeezus that must be close to 2.4 kilos per horsepower!
#6
prodat
Posted on: 2005/10/21 14:49
Didn't quite manage the 15s but close. No problems with wheel spin but more with bad understeer.
He has put D01Js on the back but have alot of difficulty getting serious rubber on the front, i.e. Semi-Slicks in 195s for a 16" rim. Another problem is lifting one of the rear wheels causing the one to spin on one or two corners. A decent sway bar will be going on to try and fix that a little. Any other ideas? As for mods, S13 SR20DET, Microtech ECU, GCG GT28 turbo (not the S15 T28), Aftermarket filter and custom mandrel bent exhaust, diff is a borg warner LSD (out of a VN V8) 3.9 ratio. All fully engineered and street legal. Slightly off topic but I managed a 1:10 is the S15 - Oh Yeah!
#7
2QK4U
Posted on: 2005/10/22 9:12
is the VNSS diff similar too the skyline R31 borg warner? i know the ratio is 3.9 also but not sure about LSD. what should i expect to pay for a ss diff disk to disk? what ratio do s13's run standard is the ratio's similar eg. apparentley with standard ute diff and s13 box the engine runs 4000rpm at 100km/h in 5th.
#8
prodat
Posted on: 2005/10/22 9:32
Not sure of the difference between the R31 and VN diffs.
We got the SS LSD disk to disk shortened and installed drive away for 3K engineered. S13's had something like 3.8, 4.1 any maybe even a 4.4 but I can't be sure. I ran a CA18DET 1200 ute with the locked 1200 diff before going to the conversion above with the S13 box and it didn't rev that high from memory (could be wrong!) I will have some pics up in the next couple of weeks of the trip to Wakefield, some real keen shots.
#9
2QK4U
Posted on: 2005/10/22 10:44
oh k sweet. could you check with mini me what revs @ 100km/h please - will help heaps. oh and the ute is absolutley awsome - real inspiration for my ute!!
