engine touble!!!
From mildura, victoria
hey guys i am having a bit of trouble with my motor in my ute. its a stock a12, i was driving around home tonight doing burn outs not really flogging it though and then when i was just driving normaly it started to cut out like it was running out of fuel then it just stopped. and i still cant start it it turns over starts for about 2 secs then dies again. could it be a fuel blockage or sumthing? there is heaps of petrol in it to.
any help would be appretiated
cheers ben
Posted on: 2005/10/24 12:05
Re: engine touble!!!
Take the fuel filter off, and make sure fluid runs through it. It might be blocked, which can cause symptoms such as you describe.
Posted on: 2005/10/25 8:02
From Canberra
Yep sure sounds like a blocked fuel filter to me.
Maybe you were flogging it after all.
Posted on: 2005/10/25 8:08
From SE Melbourne
I would check the ignition coil too, sudden dying of the car can often be related to ignition - check all leads coil, distrubutor, check condition of ignition coil...
Posted on: 2005/10/25 8:30
Mildman, Datsunless
yea i was giving it a bit but nothing like i usually do. i will take the fuel filter i need a new one so it could be that.
cheers
Posted on: 2005/10/25 8:44
