« 1 2 (3) 4 5 »
Re: LSD FOR 1000 OR 1200
From Perth
So I should keen an eye out for a H165 then
What did they come in besides utes..... and what ratios are available ?
Posted on: 2005/10/25 13:28
From Brisbane
H165B Type I (to 6/79): 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875
H165B Type II (from 7/79): 3.364, 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875
available from production vehicles: 3.7, 3.9, 4.111 & 4.875
You can get 4.1:1 and 4.875:1 ratios quite easy, it is the same diff that Bluebirds (rwd Maxima) and C20 (Datsun Vanette) -- some with aluminum centers -- and some 4wd Datsun Pickup (non-1200 ute) front diffs (those are wider assemblies, though, so just use the center section). For example:
A10 Stanza/HL510 (1978-1982): 3.7:1
180B (610) wagon: 3.89:1
Series 1 Bluebirds (810): 3.89:1
Series 3 Bluebird wagon (910): 3.89:1
Thats from the tech section... there is also a refernce for the cars in detail on there.
Posted on: 2005/10/25 13:35
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
Will a 1200ute diff fit in a 1000 with no housing mods?? Open in new window
Posted on: 2005/10/25 14:22
Has the photo come through ok??
Posted on: 2005/10/25 14:42
Nope, sorry bub.
You seem to be using the [img] tags correctly. Problem is location of your pic.
Posted on: 2005/10/25 15:15
From Okinawa, Japan
Yeah the photo needs to be on the internet somewhere, like if you posted here in the photo alblum. You're just entering the location on your computer, which is why you may be able to see it, because your computer knows where it's at.
Posted on: 2005/10/25 16:01
From sydney
Unless you are planning to chop down a ute diff its a waste of time for a 1000 as its too wide.
But then again you could run front wheel drive offset wheels on the back with a ute diff.
Posted on: 2005/10/26 0:31
From Gold Coast, Australia
IM keen for the H165 LSD for my ute. whats invovled do i keep my complete housing and modify/change the centre? Im on the gold coast.
Posted on: 2005/10/26 1:53
3RD TIME LUCKY WITH THE PHOTO?? Can you guys see it??
Posted on: 2005/10/26 3:41
Another view....
Posted on: 2005/10/26 3:47
« 1 2 (3) 4 5 »
