Re: Idle Screw ??
From Melbourne, Australia
It's sometimes hard to say what can be wrong without driving it....but l would start with..
check the air filter...can be dirty/blocked and need replacing
make sure all vacuum lines are attached and where they should be.
You can try just turning up the idle speed, but if it idles fine normally, and only stalls when slowing down, then l'd think it's something else.
Oh yeah prob best to adjust idle screw when hot, as this is the condition it will be in when driving (use choke when cold!)
Posted on: 2002/10/7 11:46
Subject Poster Date
     Idle Screw ?? amshaw 2002/10/7 9:51
       Re: Idle Screw ?? cleaner 2002/10/7 11:38
       Re: Idle Screw ?? andos 2002/10/7 11:46
       Re: Idle Screw ?? Dragongoose 2002/10/7 14:28
         Re: Idle Screw ?? dimlight65 2002/10/7 15:00
       Re: Idle Screw ?? ang94541 2002/10/7 23:36
         Re: Idle Screw ?? ddgonzal 2002/10/8 4:45
           Re: Idle Screw ?? amshaw 2002/10/8 6:14
             Re: Idle Screw ?? amshaw 2002/10/9 2:46
               Re: Idle Screw ?? andos 2002/10/9 3:14
                 Re: Idle Screw ?? amshaw 2002/10/9 3:26
                   Re: Idle Screw ?? 1200rallycar 2002/10/9 3:31
                     Re: Idle Screw ?? 1200rallycar 2002/10/9 3:35
                       Re: Idle Screw ?? amshaw 2002/10/9 3:42
                   Re: Idle Screw ?? ang94541 2002/10/9 6:43
                     Re: Idle Screw ?? 1200rallycar 2002/10/9 10:01
                       Re: Idle Screw ?? Dragongoose 2002/10/9 16:10
             Re: Idle Screw ?? ddgonzal 2002/10/10 4:19
               Re: Idle Screw ?? amshaw 2002/10/10 8:13
                 Re: Idle Screw ?? amshaw 2002/10/10 12:43
                   Re: Idle Screw ?? RICLAGE 2002/10/10 13:45
                     Re: Idle Screw ?? Dragongoose 2002/10/10 17:09
                       Re: Idle Screw ?? dimlight65 2002/10/10 19:39
                         Re: Idle Screw ?? ddgonzal 2002/10/11 3:00
                           Re: Idle Screw ?? amshaw 2002/10/25 12:16
