L20 into datsun1600
hey just wondering what i have to do to put an l20b motor in my 1600. lots of theories out there but does anybody actually know? cheers chris
Posted on: 2005/11/2 11:03
Re: L20 into datsun1600
From Adelaide, Australia
Yeah it bolts in no problems, just a little taller than L16, L18. Oh and if its a elec ign L20 out of bluey then you'll have to modify wiring to suit and grab elec coil. But really you should post this on a 1600 forum.
Posted on: 2005/11/2 11:18
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
you have to use an L16 sump and oil pickup as well if you want the L20 to go straight in.
Posted on: 2005/11/2 14:02
Also crank has 6 flywheel bolts instead of 5 (L16-18) so be sure to grab flywheel for this too... Clutch/pressureplate etc is same...
Posted on: 2005/11/2 14:53
IPRA Build
From south sanfrancisco, cali
dude... no joke
the motor bolts right in...
the other posts are right though too "oil pan"
other than that... it fits..
but be sure to use "shorter" motor mounts, because the L20b is taller than the L16... i recomend using a 5 speed ZX tranny with it
Posted on: 2005/11/3 1:45
From PERTH, WA
YEAH L20 FITS IN EASY, JUST USE THE L16 OIL SUMP AS IT FITS AROUND THE CROSS MEMBER UNLESS YOUR GONNA MODIFY EITHER, JUST DONT BELIEVE THE DIPSTICK AS IT IS WRONG WHEN YOU CHANGE FROM L16 SUMP TO L20 SUMP. I SUGGEST A 240C 5 SPEED BOX JUST NEED TO CUT AND MINOR PANEL WORK TO THE TUNNEL TO FIT HER IN, BOLTS STRAIGHT UP , IF LOOKING FOR A PERFORMANCE ENGINE MAKE SURE YOU GET A AUSSIE BLOCK AS THESE ARE BETTER THAT THE JAP ONES, HOW EVER THE JAP CRANKS ARE BETTER SO MIX AND MATCH IF YA CAN.
Posted on: 2005/11/3 4:01
