Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#2
Re: Fuel injection set up for sale
2QK4U
Posted on: 2005/11/5 5:56
how much? whats included? some details please.
#3
sidedraught
Posted on: 2005/11/5 7:53
how much? whats included? some details please. Quad 50mm throttle bodies,custom A series manifold, fuel rail ,injectors, Motec all ready to bolt on and drive away. You will have to get yourself a high pressure fuel pump. This is off a 200HP race motor so it is not really designed for a street motor ,but perfect for race use. The price is $2000.
#5
pager
Posted on: 2005/11/7 12:44
will it need retuning on a new engine? i have an a15 so it should bolt up?
#6
sidedraught
Posted on: 2005/11/7 20:51
It came off a bored out A15 and worked fine then, so it should be a bolt on and drive away scenario.
#7
datrat_dave
Posted on: 2005/11/8 7:26
Isnt this converted's old Injection out of the coupe?
Good luck with the sale anywho..
#8
sidedraught
Posted on: 2005/11/8 10:06
Its off John Taylors engine (the pic), which used to be in the coupe before it was sold to Craig.
#9
converted
Posted on: 2005/11/8 12:05
This is an awsome kit for an A series...I bought it with the hope of getting John Taylors engine, but couldnt pry it out of him. I was going to put it on mine but have since sold the A series gear and traded for the SR.
The SR has custom EFI Hardware and will have an ECU setup which will have launch, traction and data logging, but is well over double the price of this setup. (maybe triple if I go a motec!!) I really needed the 2 litres to be able to compete with the other 2 litre lads. This is a good price... I believe you can use this for the street by simply retuning the Motec and also choking the 50mm bodies down to 46mm using 2mm gauge 50mm O/D alloy tubing.
#10
dattoman_1000
Posted on: 2005/11/8 13:07
I'd love it for my A15
But seems someone cut down my money tree while I was at work Good luck with sale...... if you still got it in 6 mths let me know You can view topic.
