Brake upgrade info required
From Brisbane, Narangba
Just a quick question for those in the know. Im currently running a 120y PBR brake setup on the 1200. If i dont have to I dont want to go to stanza struts as id like to keep the track the same as it is. Im sure ive seen on here that these brakes share the same hub size as the stanza, therefore allowing for stanza discs and the like to be bolted on. Is this true?
Basically i want to keep the same strut setup with larger discs and calipars if possible.
Cheers
Posted on: 2005/11/7 10:45
Subject Poster Date
     Brake upgrade info required Freak 2005/11/7 10:45
       Re: Brake upgrade info required Grunterhunter 2005/11/11 10:33
         Re: Brake upgrade info required nzdatman 2005/11/11 22:36
