gemini radiator and thermo fan
From canberra act
hi has anyone done this here and what was involved.i am putting a a14turbo into my datto ute and think it will be gettin hot.are there any ather radiators that fit in easily without moany mods
Posted on: 2005/11/11 0:02
Re: gemini radiator and thermo fan
From Bunbury Western Australia
I have been told that a TF gemini Radiator is a good fit, I am looking for one at the moment to put in front of my A15
Posted on: 2005/11/11 1:13
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From canberra act
thanks mate what do you hook the thermo fan up to
Posted on: 2005/11/11 1:16
you can run the thermo fan from a thermostat individually mounted on the radiator and have it fed straight from the battery through a fused lead
Posted on: 2005/11/11 1:19
From T'ville
s13 silvia also fit well
datsun 620? me thinks
Posted on: 2005/11/11 1:53
From Canberra
Also N13 pulsar radiators are big, efficient and just fit. See my photos for details because I dont know how to link it to this post.
Posted on: 2005/11/11 4:00
From Canada, B.C , Richmond
Um, im not sure if you have these cars in aussy. Im using a rad from a MG.
Posted on: 2005/11/11 4:12
From Stray-ya
I am running a pulsar radiator in fornt of my A15 as well. I thought it was an N13 but looking at 1200coupe's it cant be cos it has plastic tanks, alloy core and the radiator cap is on the other side, on a stalk that sticks into the engine bay by about 100mm. will post a pic
Posted on: 2005/11/11 6:01
From Canberra, Australia
Here is a picture of how I mounted my gemini radiator.
just bolted int to the fron of the car and used some small lengths of pipe to space it out...
If I did it again I would probably put a long length all the way down on each side...
But hey... This works...
Haven't got a thermo tho.
Posted on: 2005/11/11 8:54
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From Melbourne, Australia
i never had a problem with the gemini radiator when running an a15, but after fitting the turbo setup it wasnt capable of keepin it cool anymore, i've now just installed what i think is a pulsar radiator, i still havent got that working perfectly but with two thermo fans hooked in (1 10" and 1 12") with a bit of mucking around it should be fine
just my experience... a mate of mine is having trouble with a brand new gemini radiator on an a-14.... but i guess there's always other factors that could be influencing
i'd say use a proper thermo control and a relay to wire in the thermo fan so its only sucking power when it needs to
im actually looking at fitting an oil cooler as my turbos are oil cooled only
Posted on: 2005/11/11 9:07
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
