Any one have experience with car alarms?
From Canada, B.C , Richmond
Hey there guys, Christmas is fast approching and was thinking about buying a Car alarm over boxing day sell. I never knew the area i lived was so rough so ive desided to try and have a super sensitive alarm installed. ( Broken in twice, Car was completey stolen once, tried to open doors once)
I have never really looked closly at how they work.
My question is , has anyone here gotten one installed? and is it even possible on such a old car with door mechanism unlike most cars?
Posted on: 2005/11/14 0:29
Re: Any one have experience with car alarms?
From Tamworth, NSW
This thread has a bit in it about alarms
Posted on: 2005/11/14 0:36
Hum, thread was kiinda confusing since i dont have power anything. Ive read up on How car alarms work on www.howstuffworks.com. Still wondering if any one has done it to a car with no power windows or power locks
Posted on: 2005/11/14 3:15
From sutho shire, NSW, AUS
All you need, i think, is a shock sensor and a remote, most shock sensors have veriable sensitivity so you can make the alarm go off if a loud car drives past or only if somone jumps on the bonnet. You arm and dis-arm the alarm with a reomte. These are not immobilisers and do nothin but make a loud noise whn tripped.
Posted on: 2005/11/14 3:19
Thanks alot, i was wondering if it is possibel to get one that remote locks my doors on such an old car?
Posted on: 2005/11/14 4:20
you can get soilnoids that will pull your door lock buttons down...they are heaps fiddly to put in and make work but it can be done....and its sooo cool to walk up to an old car and have it go 'beep beep'.... the next thing you need is remote start....haha.
Posted on: 2005/11/14 4:27
That is the problem, on my b10 there is no knob to push down. The hadel for teh doors doubles as teh lock. Pull it towards you to open, Push it to lock! haha
Another thing is how many shock sensors can you get from a kit? Im guessing the more the better
Posted on: 2005/11/14 4:34
From Wamboin near ACT(canberra)
i have an alarm, immobiliser, wheel movement sensors and shock sensors in my 1200 ute. i had the option of getting central locking also put in 4 $100. It can be done. you can buy packages which include instillation. The shops also say that nearly every car no matter wat sort can be fitted with and alarm. go ask a pro and they will tell you if its possible. Good luck
Posted on: 2005/11/14 7:01
From Ipswich,QLD
MAKING A CHEEP CAR ALARM
you will need > a seperate horn that works one flasher can and for door switchs and something to mount the horn on such as fibreglass so its not earthed , a fuse and a on/off switch
mount the horn where its hard to get and its not earthed then run the earth to the door switchs you will have to mount .
Then with the +possitive side from the battery place the fuse as close to the battery as possible then connect the on/off switch obviously where its hard to find .
then you can run the + to the flasher can and wire it to the horn .....
FLICK YOUR SWITCH ON AND OPEN THE DOORS AND YOUR HIDDEN HORN SHOULD BEEP OFF ITS HEAD OFF
Posted on: 2005/11/14 7:12
