32/36 adapter
From Okinawa, Japan
Will a 32/36 adapter that will bolt to a 1978 ute bolt up to a 1970 A12, or did they change carb patterns somewhere in between there?
Posted on: 2005/11/16 13:05
Re: 32/36 adapter
From Brisbane, Australia
Same Carb=Same Mount
edit: didn't see the change of carb between models bit. I wouldn't have thought so.
Posted on: 2005/11/16 21:58
Re: 32/36 adapter
From Okinawa, Japan
I guess a better way to word it would be did the 1978 ute A12 use the same carb (or at least the same carb to manifold pattern) as a 1970 1200?
Posted on: 2005/11/17 0:23
Re: 32/36 adapter
From Ipswich,QLD
If you have the packaging for the adapter plate it should have a chart on what it will fit, or if you have the brand name of the adapter google it you should find something in relation to fitment
Posted on: 2005/11/17 3:33
Re: 32/36 adapter
From gold coast QLD australia
All A series manifold to carb patterns are the same,so the adaptor will fit all models.GREG
Posted on: 2005/11/17 8:43
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
Re: 32/36 adapter
From Okinawa, Japan
Thanks a bunch for your help guys.
Posted on: 2005/11/17 23:40
