« 1 (2)
Re: What Mods would a Perfect Racing 1200 Coupe Require????
From Christchurch New Zealand
I LIKE THE COUPE BEST SO THATS WHAT THIS IS GOING TO BE
KEEP IT LIGHT A 15 BORED OUT TO 2LTR AND RESLEAVED (IF POSSABLE) FORGED PISTONS, RODS ,CRANK ,G.T.i.R QUAD THROTTLE BODYS ,12:1 COMPRESSION RATIO ,MOTEC M8 COMPUTER,LIGHT FLY, PUNMATIC TITAINUIM VALVES , DRY SUMPED ,ELECTRIC DIZZY
NOW THE GEARBOX SUNNY 5 SPEED RIP THE GUTS OUT GET A CUSTOM DESINGED 6 SPEED HYDRAULIC SEQUENTIAL SHIFT TITAINUIM DRIVESHAFT CUT DOWN FORD 9 INCH DIFF
FRONT END
BILSTIEN HIGHT ADJUSTABLE STRUTS ,CAMBER PLATES WILWOOD 4 POT CALIPERS VENTED SLOTTED DISC BUT NOT DRILLED ( AS THEY CRACK) 22MM SWAY BAR ROSE JOINTED BOTTOM ARMS AND CASTOR RODS NOLATHANE RIGHT THROUGH
REAR END BILSTIEN UPRIGHTS WITN EXTRA LEAF PUT IN AND RESEAT - 5 DEGRES WILLWOOD 2 SPOTS AND SLOTTED AND VENTED DISC
STEERING HIGH RATIO STEERING
1 TURN LOCK TO LOCK
NOW THE BODY SHELL LIGHTEN THE HELL OUT OF IT TO COMPESATE FOR THE SIX POINT CAGE KEVLAR DOORS BONNET BOOT FRONT GUARDS, REAR GUARDS , ALL WINOWS ARE NOW LEXIAN MR10
BEAR IN MIND IF YOU BUILD YOUR MOTOR RIGHT IT SHOULD HAVE 400 HP THAT IS THE MAXUIM YOU WILL EVER GET OUT OF A NA
2 LTR
RUN THE MOTOR IN BEST FOR 2000KMS AND USE FULLY SINTHETIC OIL AFTER THE FIRST OIL CHANGE GO TO TRACK ABSOLOUTLY RING ITS NECK
OK NOW IF FINISHED MY LITTLE DAY DREAM AND CRASHED BACK INTO REALTY
Posted on: 2002/10/16 6:35
"If your not living on the edge your taking up too much space" Rod Millen
From Canberra, Australia
what is the biggest that you can get an A series out to?
Posted on: 2002/10/16 6:49
From Brisbane
The biggest you can have an A series motor out to would be 1500, you know what I found once that the e15 is exactly the same capacity and size piston and same piston and rings in size as the A15 and E16 r now this crank in the E16 with its conrods should fit in the A15 or A14 as the A14 and A15 have the same piston diameter, just the strokes are longer in the cranks from A15 to A15, like E15 to E16,,,ahhhhh only one problem remains will you need a lower piston height or shorter conrod?????
I need more info before confirmation
Well well e15 has 82mm stroke and the E16 has 88mm stroke now what is the conrods??
Posted on: 2002/10/16 16:11
« 1 (2)
