#1 Stumpy CA18DET Questions
matbighat Posted on: 2005/11/24 3:29
Using the CA20e bellhousing on a stumpy 5spd for CA18DET ...
1. Which backing/dust plate?
2. Which starter?
3. Which t/o bearing?
4. Which shift fork?
5. Anything else you want to add
We really should have a tech article on this ...
#2 Re: Stumpy CA18DET Questions
short_coupe Posted on: 2005/11/24 11:33
i actually did it with the CA18 bellhousing
1. CA18det
2. CA18det
3. CA20
4. CA20
5, i think you find CA 20 and CA18 starters and sandwich plates will be the same, the CA box is stronger and has better ratio's.
Heath
#3 Re: Stumpy CA18DET Questions
short_coupe Posted on: 2005/11/24 11:41
another thing, i had to get a sleeve made, for 1 of the selector shafts, 1 of the 3 on the stumpy was smaller than the CA18 ( but i don't exactly know about the CA20 selectors), i went back to the CA box once people were breaking the stumpy's behind CA powered 1200's. Heath
#4 Re: Stumpy CA18DET Questions
matbighat Posted on: 2005/12/2 5:29
Thx sc, now hopefully somebody who did the ca18det/stumpy can answer the rest 'o the questions.
Let's go lazys ...
