#1 I need a diff to handle 4agze (supercharged)
Quinn Posted on: 2005/11/24 8:50
Hey Im putting a 4agze into my 1200 and I need to sort out a diff for it. I have a H165 and was thinking of geting an LSD for it but Im not sure if it will handle the torque. I dont want to spend heeps on the LSD just to find the axles keep braking. Should I go for the H190? I didn't want to have to shorten the dif plus pay for an LSD, welding the diff is out of the question and I dont really want to have to re-engineer a diff to fit the 1200. Any one got sugestions?
Thanks.
#2 Re: I need a diff to handle 4agze (supercharged)
Wogboy Posted on: 2005/11/24 9:49
Quinn Ive got the same motor in mine but now turboed but back to the diff Q I went for the r31 skyline option can get a bit expensive but if you do a search you shuold find a few others (sprinter, hilux and so on ) good luck
Michael
#3 Re: I need a diff to handle 4agze (supercharged)
low1000 Posted on: 2005/11/24 10:13
i can 2nd that choice of the r31 diff. it will be a bit more expensive to start with but will be stronger than most other diffs out there.
Elliott
#4 Re: I need a diff to handle 4agze (supercharged)
kegs Posted on: 2005/11/24 10:37
if its only a stock gze they have #### all power anyways so just use stocker diff. ive seen ppl with more than stock ca18's with stock diff.if it doesnt hold up just change the diff to a h190 bluebird diff noone will ever know its been changed....
#5 Re: I need a diff to handle 4agze (supercharged)
1200rallycar Posted on: 2005/11/24 11:21
i have the h190 vanette diff, its 45mm wider, will take any power (its like 8.5+ inch)
fwd offset or 2" flares will cover the extra width
instalation requires new tailshaft, and relocating the mounts (cut off weld back on closer in)
discs from bluebirds bolt straight on and brake lines match up (change them over to the vanette axles)
#6 Re: I need a diff to handle 4agze (supercharged)
WhiteSedan Posted on: 2005/11/24 11:29
H190 is actually 7.5inch
#7 Re: I need a diff to handle 4agze (supercharged)
1200rallycar Posted on: 2005/11/24 11:33
maybe so, to be honest i was told that and didnt actually measure it, still it will take the power
#8 Re: I need a diff to handle 4agze (supercharged)
WhiteSedan Posted on: 2005/11/24 11:55
Well H190, 190mm ring gear, 190mm = roughly 7.5inch, hell look at the power you can put through a ford 9inch!
#9 Re: I need a diff to handle 4agze (supercharged)
2332owner Posted on: 2005/11/24 11:57
You don't have to measure it... 190mm is like 7.48 inches or something.
#10 Re: I need a diff to handle 4agze (supercharged)
2332owner Posted on: 2005/11/24 12:04
beat me to it
(1) 2 3 »
