Re: Door locks
From Sydney, Australia
I never buggered mine, and they were jaycar specials..I've seen mine not lock a few times because a door is not closed properly..
I guess it's possible, but it appears that if they won't go down, they normally pop open again. The alarm will arm, but your doors won't be locked.
Water is the biggest killer for the solenoids. Try and mount them so water won't easily run down the shaft, and run silastic around the casing where the fusion weld the plastic shell together. You know water gets them when they stop working and become very "ratchety". The little electric motor rusts and siezes. WD40 and a good wash down with metho normally fixes em up again..
Chris
Posted on: 2002/10/17 7:15
Subject Poster Date
     Door locks ernals_ute 2002/10/17 1:05
       Re: Door locks andos 2002/10/17 1:14
         Re: Door locks 1200rallycar 2002/10/17 1:25
         Re: Door locks ernals_ute 2002/10/17 4:27
           Re: Door locks dattodude 2002/10/17 7:15
             Re: Door locks ernals_ute 2002/10/17 11:24
               Re: Door locks Lobster 2002/10/18 9:18
                 Re: Door locks 1200rallycar 2002/10/19 15:18
       Re: Door locks dattodude 2002/10/17 3:42
