Carburetor
From Kuala Lumpur, Malaysia
I would like to apologize to this forum's
administrators and users if my post seems
out of place here.
I'm from Kuala Lumpur, Malaysia.
I'm a Toyota Corolla "DX" KE70 owner, with a 1,290 cc 4K engine, 1981 model. I have changed the carburetor three times - a used one at first, then two brand new ones. The current new one is still giving endless rough idle problems, and I have read this is common with these problematic Aisan carburetors.
I'm considering changing over to the Datsun 120Y B210's A12 engine's Hitachi carburetor, or perhaps that of the B11 Sunny's , and I wonder if
it can be installed in my engine ?
Thank you.
Posted on: 2005/12/5 9:32
Re: Carburetor
From Adelaide, Australia
An A-series carb will not fit, wrong bolt spacing. L-series carb will fit no worries, you'll have to rejet and work out linkage and emissions etc.
Posted on: 2005/12/5 9:52
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Carburetor
Thanks very much, I will check this out.
I believe the L-series were older engines were
used on the Datsun 1600 SSS, etc ?
Posted on: 2005/12/6 3:18
Re: Carburetor
From Brisbane
im pretty sure they came out in Z cars aswell
Posted on: 2005/12/6 7:36
Re: Carburetor
From Sydney, Australia
Hi Tham, the 1600 SSS uses twin SU type carburettors, not what you are looking for.
Are you sure that your problem is the carburettor? It's not ignition related or a blown head gasket or something else?
Good Luck with the fix!
Posted on: 2005/12/6 8:02
Re: Carburetor
I tend to agree. Tried 3 other carbies and still the same problem. Time to look elsewhere.
Maybe manifold leak,
maybe rocker clearance,
maybe burnt valve.
Lots of things besides carbie.
Posted on: 2005/12/6 8:46
Re: Carburetor
Thanks, Dattodude, Phunkdoktaspok and Maztec.
The basic problem is basically, right after starting
up, the idle speed seems OK. If I drive off the car at
speed, and I don't get held up much by traffic, it will
run fairly well too. However, if I leave it at idle right
after starting, or if I get held up by traffic after some
running, and the temperature gauge starts climbing
towards to the 2/3 or middle position, the erratic idle
starts to come in, with the engine sputtering a bit,
close to dying. It did die off once, but I managed to
start it back, though with the engine sputtering and
struggling to hold idle. I only managed to keep it from
dying again by pulling out the manual choke as a last
resort. I can't really figure out what's wrong, but think
it's the idle circuit in the carburetor.
Yes, I did have the mechanic tighten the manifold
nuts, suspecting a manifold leak too. The head
gasket has just been changed, valves decarbonized,
valve seals replaced and rocker clearances adjusted.
The mechanic is really scratching his head too.
(The mechanics over here aren't particularly skillful,
though.)
The ignition system was the first to be suspected.
I'm using a contact points-triggered electronic ignition
system made from a kit by Dick Smith Electronics,
Australia, originally designed by Silicon Chip magazine.
I tried switching back to the standard points ignition,
but it was the same. The contact points and condenser
have just been changed too.
Initially the vacuum advance pump at the distributor was
causing this rough idle problem too. What happened was
the original pump had given way, and the only replacements available here were generic "Century" brands made in Japan (or so the label said, but I suspect more likely from Taiwan). Well, this pump has a plastic adjuster at the rear for fine timing adjustments. The stock Nippondenso one was very well made and heat durable, but this replacement's adjuster was not, and virtually disintegrated from the heat after a few months. Once this happened, the timing went haywire, since this adjuster was at the end of a tensioner spring indenting against the pump's arm connected to the distributor's plate.
I had to buy another pump, same thing happened after
a few months again, before my brother-in-law finally fashioned
a copper adjuster and screwed it in. The ignition timing
at idle appears to be holding well since then.
The spark plugs, plug leads, ignition coil have all been
replaced. Fuel pump and filter have been changed too.
After the second carburetor change, the problem
appeared to go away after I replaced the mechanical fuel
pump, suspecting it didn't have enough pumping
capacity anymore. It's just over a year since, but I'm
wondering whether this pump is starting to give way too ?
There are lots of Taiwanese parts being passed off as
Japanese ones in Malaysia.
There is a quite a bit of discussion in the forum in the
Toyota Starlet website (www.kp61.net), that the stock
Aisan carburetor is not very well designed and prone
to all kind of rough idle problems, virtually impossible
to correct with the idle mixture and idle speed screws.
The Starlet in the US has the same 1,290 cc, 4K engine
as my Corolla, and basically the same Aisan carburetor.
One owner complained his idle speed varied anywhere
from 700 to 1,000 rpm !
I had also read in the forum of a Suzuki jeep website
(can't really remember the URL), which also comes with
Aisan carburetors, that this is the case too. The owner who
made the post mentioned that the source of this rough
idle problem appeared to be a "power piston" in the idle
circuit. The function of this piston is to enrichen the
mixture during low vacuum conditions, such as idle.
If there are even micro-abrasions in its chamber,
possibly from wear and tear, the piston will behave
erratically, the mixture will become way to rich, and
the engine will likely sputter and die. This owner was
quite innovative - he managed to rebore the chamber
and replate the piston or something, and the idle was
fine after that.
This is one jinxed car, but I'll try checking out for things
like manifold leaks, igntion and fuel pump problems again.
Posted on: 2005/12/6 15:31
Re: Carburetor
From Brisbane, Australia
I'm no expert but it might be vapour lock. The fuel line or carby gets hot & the fuel vapourises. Or it could be water or dirt in the fuel. It definitely sounds fuel related.
Posted on: 2005/12/8 14:05
Re: Carburetor
Thanks, Vex. Yes, it may well be vapour lock.
How does one really cure vapour lock ? I've
read about switching over to electric fuel pumps,
but the mechanics over here don't really know
how to handle this kind of modification.
Posted on: 2005/12/8 15:27
Re: Carburetor
From Tamworth, NSW
plenty of carbie cars had electric fuel pumps. 1 comes to mind honda accord 1980 up to 1988? it should be reasonablely easy to convert it to the corolla you just need to mount it an connect it up
Posted on: 2005/12/9 9:19
