#1 blinkers stuffing up again...
maztec Posted on: 2005/12/13 6:54
hey... i fixed the blinker problem last time (jiggled wires around a little bit and it temporarily fixed the problem of causing both blinker lights and the dash lights to flicker) does it sound like there is a bad earth in my car ????anyone got any remodies to fix this problem?
cheers
shaun
#2 Re: blinkers stuffing up again...
Widget Posted on: 2005/12/13 8:23
Or mayb a short in the connection, check the small things like the fuses aswell, sometimes they can also loose contact.
#3 Re: blinkers stuffing up again...
chris1200t Posted on: 2005/12/13 9:07
im pretty sure i had the same problem and the answer is the fuesible link between the battery and the cars lights and such try having a look at it and most likely itl be ####ed and if you give it a jiggle the power should come back to the car but best bet is to get a new link.
cheers
#4 Re: blinkers stuffing up again...
Steveo_1987 Posted on: 2005/12/13 11:53
shaun i had the same problem with the mini. have u got the dash lights earthed coz wen i was doin the mini i didnt and all the lights on the car were blinking. once i earthed it, it worked. also check to see if the flasher unit has a good connection and also check ur wires make sure theres no bad connections. after a bit of playing around u should get it.
lata
