more carby questions
From Bendigo, Victoria, Australia.
can anyone tell me
do weber 40 DCOE carbs mount onto an a12gx manifold?
ive seen them on A14 with gx manifold but wasnt sure on the A12
this is a photo of an A14 with 40 DCOE's on a GX manifold
http://www.turbophile.com/feature_cars/ryan_1200_ute/engine.jpg
Posted on: 2005/12/16 2:50
Re: more carby questions
would i be better to get a manifold made at an exhaust shop?
that'd look better all polished up than this
Posted on: 2005/12/16 2:57
From Alabama, U.S.A.
Don't know how a home made one would flow , better off getting a GX manifold . It has a good flow rate that has been proven time & time a gain. (sss)
Posted on: 2005/12/16 3:10
wot about a tomei one?
like this kit here, comes with linkage and everythin.
Posted on: 2005/12/16 3:14
cept the bloody thing dint work
go to Tomei
Posted on: 2005/12/16 3:16
That would be a good one too. if u can afford one . The Tomea didn't work?
Posted on: 2005/12/16 3:25
hi all..
i have a carb question also... :)
from our modification experience.. we know that bigger carb.. will let our engine rev high easier...
is it possible to modify the stock hitachi carb to achieve this also?
i thinking maybe change the jet needle..
cause the jet needle determine the amount of opening in different throttle position.. so maybe modify or change the needle for more air+fuel mixture at bigger opening?
Posted on: 2005/12/16 4:14
From Brisbane, Australia
A Factory GX manifold was for SU style carbs.
The Weber pattern is completely different. For some reason this aftermarket manifold has GX cast on it. (JTS?)
Posted on: 2005/12/16 4:21
exactly there cable tie . and yes u can modify a Hitachi carb by changing jetts, and that means having a stock full of old Hitachi's layin around . ( all models) from A series to L series.
Posted on: 2005/12/16 4:43
the Tomei intake manifold is 42,000 Yen (thank god for that)
so that works out a bit over $500 (australian)
plus u gotta get it here from japan. so shipping would be a few hundred.
plus 2 40 DOCE's which brand new are around $600 - $700 Australian.
Jee, i cood nearly get a CA18DET by the time ive got all this
Posted on: 2005/12/16 5:45
