Re: Which coil to use with electronic distributer?
From Kuala Lumpur, Malaysia
Your distributor sounds like a stock unit
which came with the car. The ignitor is usually
built inside the distributor.
If so, it is probably the capacitive discharge type,
and will need an "electronic" type coil suited to
electronic ignition systems.
In Malaysia, you can usually buy this at spare parts
shops, under the "Diamond" brand. I think it is
used without a ballast resistor.
Posted on: 2005/12/19 4:04
Subject Poster Date
     Which coil to use with electronic distributer? SUNEE 2005/12/19 1:34
       Re: Which coil to use with electronic distributer? steveo 2005/12/19 1:42
         Re: Which coil to use with electronic distributer? SUNEE 2005/12/19 1:46
       Re: Which coil to use with electronic distributer? Cable_Tie 2005/12/19 1:44
         Re: Which coil to use with electronic distributer? SUNEE 2005/12/19 1:49
           Re: Which coil to use with electronic distributer? steveo 2005/12/19 2:03
             Re: Which coil to use with electronic distributer? SUNEE 2005/12/19 2:07
               Re: Which coil to use with electronic distributer? Tham 2005/12/19 4:04
                 Re: Which coil to use with electronic distributer? Cable_Tie 2005/12/19 4:42
                   Re: Which coil to use with electronic distributer? blofly 2005/12/19 8:04
       Re: Which coil to use with electronic distributer? evilsim 2005/12/19 8:13
         Re: Which coil to use with electronic distributer? dattoman_1000 2005/12/19 10:58
           Re: Which coil to use with electronic distributer? dattodude 2005/12/19 14:41
             Re: Which coil to use with electronic distributer? dattoman_1000 2005/12/20 11:07
       Re: Which coil to use with electronic distributer? slimpickaus 2006/1/5 2:03
         Re: Which coil to use with electronic distributer? ddgonzal 2006/1/5 5:18
           Re: Which coil to use with electronic distributer? blofly 2006/1/5 5:56
