Coilover kits and brake up grades 4 sale
From Ipswich
Hey all
Im currently making coilover kits and break up grages for 1200 coupe and 120y struts. Im using shorter inserts so that the shochies dont bottom out over bumps, and breakes are off 180sx. These breakes will fit under a 13in wheel. The ride hight is fully adjustable and if you riquire them, i can make up adjustable camber tops and caster rods. Konie Shockes will fit, but in normal situation i fit pedder sports. The track of the car doesnt change and if your interested pm me or call me on
Trent 0421316757.
I live in Australia, Queenland, Brisbane, Ipswich.
Posted on: 2005/12/27 4:44
Re: Coilover kits and brake up grades 4 sale
Hi could you do them with nissan 5 stud rotors and brakes like r32 skyline or 200sx ?
what is the price of the ones you have?
Posted on: 2005/12/27 11:23
From Ipswich
Hey
The biggest brakes ive fitted so far and fit straight onto my bracket are, s13 SA20 TURBO brakes and rotors. They only under a 15in rims or bigger. There getting hard to get hold of and they want good money 4 them. The kits i normal make up cost $1250 that if u provied the struts. That every thing, brakes, new shockes, wheel bearing, springs, and coilovers.
If u need anymore info please call on 0421316757.
Posted on: 2005/12/28 3:43
From australia tasmania
so they come in a datsun 4 stud patten do they? how much are you selling them for a set? would they fit a 1200 serdan? how would you go with the master cylinder? would you need a booster?
cheers
Posted on: 2005/12/30 9:55
old skool cool...
www.shakotangarage.com
From Ipswich
Hey
All 1200 front ends are the same. And as far as i know they all have the same wheel base. Yes they are a 4 stud pattern and so far im not able to make then into a 5 stud. I used the standed master cylinder i my car and it worked great. It gives u a firm peddle. U can run a boster if u wish.
IF u need more info give me a call. 0421316757.
Posted on: 2006/1/3 9:59
