carby question
Not too shy to talk
From perth, WA
hello
i have been reading through previous posts on 32/36 weber and am tryin to find what different members are usin to set up their accelerator cable. I have taken the bracket off the old carby but fail to see how this could work for the secondary. Would it be a case of making my own systerm or is there a part that can go straight on. I have looked at different options but can only make the secondary open at the same rate as the primary, Im not too sure if this is correct. Any help would really be appreciated or perhaps close up photos of your personal set up.
cheers
Posted on: 2006/1/12 4:24
Re: carby question
im using the stock hitachi bracket that holds the cable and bolted this to a metal bracket that i found in a bucket of stuff my mehanic had lying around and bent the bracket slightly to the right angle in a vice using a hammer.
Then i mounted the other end of the longer metal bracket to top of a bolt (one of the 4) that hold the carby onto the manifold adaptor..... its crude but for $0 its great and works! The metal braket looks like an alternator bracket of a pulsar or some crappy front whell dirve car..
Posted on: 2006/1/12 9:45
