Re: a/c in Datto ute?
From WA
electric AC compressors
there is a contact in AU for these
http://www.geocities.com/radiatorexpert/
nigels@cooldrive.com.au
you'll need 100AMP alternator to run them though.
Posted on: 2006/1/13 1:17
From Warwick, QLD
so what is exactly needed to A/c a 1200. You need a compressor, condenser, evaperator (how bulky are these parts?) Then tubing? What tubing is used could you make it up yourself?
Cheers
Damo
Posted on: 2006/1/13 7:00
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From Adelaide, Australia
Most of its pretty heavy, condensor is like a radiator and would sit in front of radiator, compressor (same size as 2 alternators) sits on passenger side of engine(A-series 74+) and then evaporator sits up under dash and takes in air from cabin cools it then sends back into car so would have to plumb hose from that into hoses that run to demister i guess. As for hoses that carry the gas, i would use the ones off donar car personally.
I dont know anyone whos done it, but i think ive got it layed out in my head. The only complicated thing is the wiring, idle setup etc, and getting the air into the cabin properly.
Posted on: 2006/1/13 7:12
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
I dont feel any of it is real heavy. Condensors are as thick as an oil cooler (20mm), The bigger the surface area, the better cooling, most come with mountings for receiver driers on the sides of them. Compressors are sized for motors, so using one off a 2litre motor on a A series would be putting pointless load on the motor. A compressor sized for a 500cc - 1400cc motor, is a little bit bigger than an EA ford 80amp alternator. Using a smaller compressor on a bigger motor is not a problem. The bigger the cabin area, the more gas you want to compress quicker, thats when you want a bigger compressor, Just like house A/C systems. You can mount the compressor on any side of the motor aslong as you (a) make the mounting, and (b) line it up with a pulley so the belt runs smooth.
The evaporater works opposite to a radiator, Where as it cools the air blowing through it and removes the moisture (humidity) from the cabin. This moisture is dumped through a drain tube to underneath the car. Any auto elec that does A/C will have a catalogue you can look at which has dimensions of aftermarket underdash units.You can still buy the similar style units as to what nissan dealers fitted to 1200s.
You can easily fit up the components yourself. The underdash units require basic wiring ( easier than a radio) and they come with diagrams.
You can buy the rubber high and low pressure lines buy the metre from pirtek etc, cut it to length and then get the correct fittings crimped on buy the same shop etc. Then oil and gas at the auto elec etc. Most aftermarket fitouts use a rpm trigger which cuts out the compressor below a set engine rpm, this makes engine idle not difficult at all.
Posted on: 2006/1/13 10:40
From Buttaba (Newcastle) Nsw, Australia
this is a rooftop a/c in a car.
Posted on: 2006/1/13 11:01
« 1 2 3 (4)
