Re: Using stock intake with extractors....what to do with the big hole?
From Alabama, U.S.A.
A ll of the A14's here in the U.S. have the same thing . The plate is sandwiched between the two. Just pull the two studs out & use bolts in all four , put the plate & gasket in place, then flat washers & nuts . tighten.
Posted on: 2006/1/27 2:42
Subject Poster Date
     Using stock intake with extractors....what to do with the big hole? Mildman 2006/1/26 4:29
       Re: Using stock intake with extractors....what to do with the big hole? dattodevil 2006/1/26 5:12
       Re: Using stock intake with extractors....what to do with the big hole? pager 2006/1/26 5:16
         Re: Using stock intake with extractors....what to do with the big hole? B210sleeper 2006/1/26 5:46
         Re: Using stock intake with extractors....what to do with the big hole? Mildman 2006/1/26 6:18
           Re: Using stock intake with extractors....what to do with the big hole? Ash 2006/1/26 6:43
             Re: Using stock intake with extractors....what to do with the big hole? Mildman 2006/1/26 7:32
               Re: Using stock intake with extractors....what to do with the big hole? Mildman 2006/1/27 2:00
                 Re: Using stock intake with extractors....what to do with the big hole? hotrod88 2006/1/27 2:42
