Re: 0-100km times ???
From Warburton vic
You can say what you want about beating car off the mark.
As every one should no it all comes down to the driver. To answer your question put the same driver in all differant cars & run them 0-100 then you can work out whos faster or not.
Also your 1200 weighs 700kg the average commodore weighs 1400kg so to match a V6 commo you need half the power & half the weight. If you get an a15 to make 140 HP in a 1200 you will be very suprised what it will do on the street if you can drive it properly.
Coops
P.S I am a bit pissed
Posted on: 2006/1/29 4:53
Subject Poster Date
     0-100km times ??? pager 2006/1/28 4:58
       Re: 0-100km times ??? 2QK4U 2006/1/28 5:28
         Re: 0-100km times ??? pager 2006/1/28 5:58
           Re: 0-100km times ??? 1200rallycar 2006/1/28 23:50
             Re: 0-100km times ??? ddgonzal 2006/1/29 0:16
               Re: 0-100km times ??? lidder 2006/1/29 4:29
                 Re: 0-100km times ??? COUP1200 2006/1/29 4:53
                   Re: 0-100km times ??? datto1200mad 2006/1/29 6:26
                     Re: 0-100km times ??? pepper 2006/1/29 6:32
                     Re: 0-100km times ??? rb20 2006/1/29 6:36
                       Re: 0-100km times ??? matty 2006/1/29 9:44
                         Re: 0-100km times ??? pager 2006/1/29 11:37
                           Re: 0-100km times ??? matty 2006/1/29 14:20
                             Re: 0-100km times ??? dazzasute 2006/1/29 16:02
                             Re: 0-100km times ??? Ash 2006/1/30 1:55
                               Re: 0-100km times ??? matty 2006/1/30 4:54
                                 Re: 0-100km times ??? 1200rallycar 2006/1/30 7:09
                                   Re: 0-100km times ??? matty 2006/1/30 8:35
                                     Re: 0-100km times ??? MadTimo 2006/1/30 12:51
                                       Re: 0-100km times ??? L18_B110 2006/1/30 12:56
                                         Re: 0-100km times ??? Cable_Tie 2006/1/30 22:20
                                           Re: 0-100km times ??? BigV 2006/1/31 1:22
                                             Re: 0-100km times ??? Cable_Tie 2006/1/31 1:42
                                               Re: 0-100km times ??? Demojob 2006/1/31 2:44
                                                 Re: 0-100km times ??? matty 2006/1/31 3:29
                                                   Re: 0-100km times ??? 1200rallycar 2006/1/31 6:55
                                                     Re: 0-100km times ??? L18_B110 2006/1/31 9:26
                                                       Re: 0-100km times ??? Dodgeman 2006/1/31 11:12
                                                         Re: 0-100km times ??? L18_B110 2006/2/1 0:00
                                                           Re: What chew torquin' 'bout ??? Cable_Tie 2006/2/1 1:30
                                         Re: 0-100km times ??? 1200rallycar 2006/1/31 7:10
                                   Re: 0-100km times ??? pager 2006/2/1 3:47
                     Re: 0-100km times ??? Dats-hot 2006/1/29 13:06
       Re: 0-100km times ??? datsik 2006/4/11 16:49
         Re: 0-100km times ??? SLAM1024 2006/4/12 0:31
