Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
1200 Rear ends and axle bearings
DarkBonerDatsun
Posted on: 2006/2/12 1:07
Ive been rebuilding my '72 Datsun B110 and its totally almost ready to be all put back together but the rear end is holding me up. Got the third member built no problem but locating the rear wheel bearings are proving to be a challenge (this is the start of month 3 of the search) The bearing I am looking for is a special sealed 6206 bearing that has an inner diameter of 32mm as opposed to the std. 6206 with a 30mm id. If anyone knows where I can get these bearing please mail with the info. further more in the process of removing the old bearings I actually bent one of the axle in the press so no I am also looking for that.. If anyone is parting out a '72 1200 I will purchase both your rear axles with backing plates and bearings. I need this rear end put back together so that the rest of the #### Ive dumped too much money on so far can finally be put to use.
#2
Re: 1200 Rear ends and axle bearings
Dodgeman
Posted on: 2006/2/12 1:15
I bought two bearings recently from my local Datsun dealer. He had to get one in from far north Queensland & the other from somewhere near Perth. The other parts that normally come in a kit were also bought separately.
You're right though, they are hard to come by & all the catalogues that I went through are wrong, listing the ute bearing as being for passenger models.
#3
DarkBonerDatsun
Posted on: 2006/2/12 1:45
I need to know where I can purchase these elusive bearings, this search has been driving me nuts and now I need at least one axle shaft too
#4
GreaseMonky
Posted on: 2006/2/13 2:04
I have a complet axle assembly if you are interested
#5
boondy
Posted on: 2006/2/13 7:02
I just bought a set for my ute i dont know if they are the same but i got them from cbc bearings in welshpool Perth W.A
ph 93506688 they had heaps of bearing kits or try Veale engine parts in redcliffe wa 93663666 You can view topic.
