« 1 (2) 3 »
Re: Drop The Donk ??
From sydney australia
easiest way i've found,particularly if the car is junk,is to drop the crossmember,engine,gearbox,manifolds etc,onto the ground,get 3 or 4 people at the front,then lift the body up & over the engine,gearbox etc.& pushl the car back.the front of the car is lighter,particularly with the struts out,than the engine.i learnt this method from practical experience.
Posted on: 2002/11/8 10:27
From Melbourne, Australia
thats what i said isnt it?
anyone, your all soft, lift the barstard out like i said i cant believe this is getting so many posts its no big deal, in fact be a man dont even drain the water let alone taking out gaskets and other crap to save weight
yes i am passionate about this subject i agree
Posted on: 2002/11/8 13:51
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Castro Valley,CA USA
there are 6 bolts that hold the trans to the block, 2 bolts for the starter, 2 bolts for the clutch slave cylinder ( i think you have a cable or something to undo), also there is a plate between the trans and block (at least my car has one) and there are 3 additional bolts that hold the lower half to the front of the trans.
Posted on: 2002/11/8 13:56
Hey 1200rallycar! it would be funny to see most of these guys work hey!
Fair enough there is never any need to rush but talk about making a little job seem hard!
I'm not really that passionate about this subject! but it does make me laugh!
In the end i supose as long as the engine gets out and nobody is hurt! Any way is OK!
Posted on: 2002/11/8 13:59
its better if someone get hurt cause theres usually a funny stroy to tell about that time we were taking the engine out ......
Posted on: 2002/11/8 14:01
1200 Coupe Rallycar
From Hamilton , Victoria, Australia
Ive hit a bit of a snag with my plan. I was going to use the Quickcut to cut out the front part of the sedan just to help out a bit so we dont have to lift so high over the rad support etc.
I said to my Captain that it would be a great "Training" job for the boy's and I even offerd to buy the Disk for it but he wouldent be in it because it isnt op training, Bugger !!
This might be a bit boring to some but for some of us this is kind of new and any info is good and if we can have a laugh on the way why not ?
Also as a OHAS rep so thats why I asked about just lifting out the motor, will give it a go though .
Regards
Andrew Shaw
HUFB
Posted on: 2002/11/9 0:32
Mate it's all good!
Plus it gives us something to laugh at!
Nah but really we are just here to give sugestions and hopefully help each other out!
Posted on: 2002/11/9 0:46
The Box is out and the donk is ready to come out. I had a look and Im affraid I pulled manifolds, Alt , cluch pressure plate etc off and lifted it of the engine mounts ready for a big lift !!
Regards
Andrew Shaw
Posted on: 2002/11/9 6:57
oh that's right, i forgot that you were a firefighter. I sure with all the extracation devices at your disposal you could have fillet that car in no time at all.
That would have made for an interseting picture.
Posted on: 2002/11/9 7:30
Sometime's its handy to have some of our gear on hand , but the fire service is a little differant over here. We have some extracation gear but not much ( in my area anyway), we usally leave this work to the SES ( State Emergancy Service) who cut & pull a wreak apart and get a patient out then we all help to get to the Ambo's ( Paramedic's ).
But in some parts of the State's & elsewere the Fire Dept does the lot, hooray for cross training !!
Regards
Andrew
Posted on: 2002/11/9 11:08
« 1 (2) 3 »
