HELP!! Ca18det owners
Not too shy to talk
From coffs harbour
hey guys need some help do you know where i can get the modified turbo dump pipe for the ca18det convert and how much they are??and no zorst place here will make them thanks!!
Posted on: 2004/1/2 6:47
Re: HELP!! Ca18det owners
From Sydney, Australia
Make it yourself with a 3 inch mandrel bend. The regular sized turbo outlet + wastegate section = 3 inch circumference (Could have been 3.5 inch - Please measure it on the standard dump pipe's internal diameter).
Buy the steel flange from a place like Liverpool Exhausts in Sydney. Unless you are running a big GT turbo, don't bother you won't see any benefit, use the standard one, or use a SR20DET one, they fit better in a 1200.
Only get a custom dump pipe if you need it to help clear steering, or if you are running a custom manifold, and would like something less than a 90 degree bend.
Making it yourself will cost about $60.
Cheers,
Chris.
Posted on: 2004/1/2 11:29
Spud, Give Rama a call at Arrow Diffs in Sydney on 02-9526-5955. He made me up a very nice stainless steel 3 inch dump pipe to suit my 1200 - CA18DET conversion and it clears the idler arm and firewall nicely. I bought it a year or so ago but it was around the $220 mark I think. My was one of the first he did but he's got the template now. It will save you a lot of stuffing around!
Posted on: 2004/1/2 14:29
Not too shy to talk
From coffs harbour
yeah arrow diffs dont make them anymore called them yesterday as for making it my self man i cant weld and i mean at all the stock t25 dump is to close to the steering arm but what did you mean about the sr20 dump?arrow had 1 sr20 1200 dump left wat could i use this on and would fit?i will be running a s14 t28 but after car is regoed
thanks
Posted on: 2004/1/3 1:44
