Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
280zx brakes?
jrotaryb
Posted on: 2004/1/6 19:38
I tried using the search but I need to be sure about this, what do I need to swap 280ZX brakes onto a 1200? Do I need B310 control arms etc? Thanks!!
Jon www.z1auto.com
#2
Re: 280zx brakes?
Rallytwit
Posted on: 2004/1/7 0:54
Jon , I hope this helps. On my 1200 Road Race Car I use the whole 280ZX strut , control arms and radius rod. The crossmember is modified to accept the 280 control arms , all the rest bolts up. Keep in mind the strut itself is cut down and a coil over kit installed. Before this set-up we used cut down 240 springs and the rate seemed about right. If you plan to still use 13 inch rims (I have to) you will need to machine the back of the Caliper and possible use a wheel spacer so they will fit inside the rim.
Tom Grossmann , Las Vegas You can view topic.
