F.S L18 & L20
hey, i have 2 engines for sale
L18 out of my mates 1600, complete, with engine ready to run, clutch assembly, gearbox, head has work done to it, bigger valves cam, minor flow job, is a tad low on comp, suspected burn valve or head gasket (valves are only $15 and pretty easy to put in..
engine has extractors,
L20 standard engine, new clutch plate assy, trx gearbox, cam shaft. larger valves supplyed but not installed (44mm intake) engine has extractors...
carbys x2 dellortos 40mm manifold & 32/36 top draft webber with manifold, both been cleaned out.
email me at neill.horsman@interneering.com
(photos soon)
Posted on: 2004/3/8 13:54
Re: F.S L18 & L20
bump
Posted on: 2004/3/21 1:52
Re: F.S L18 & L20
From wodonga, victoria
how much for the L18. is every thing there to do a transplant into another car.
is the manifold on the dellortos for an L series engine or an a series engine.
where abouts are you situated.
Posted on: 2004/3/22 9:33
Re: F.S L18 & L20
From Hobart Tasmania AUS
how much for the weber 32/36? What type of choke is it? Is it in top nick? Where are you? Thanks
Posted on: 2004/3/22 10:58
1968 1000 Wagon
1967 1000 2 Door Sedan (A12)
1969 1000 4 Door Sedan
1968 1000 4 Door Sedan (parts car)
1964 Toyota Coaster Bus
Re: F.S L18 & L20
hey do you think you could reply on this stuff.
what year bluebird is the L20 out of.
and do you still have the twin 40mm.
can you give me a price.
Posted on: 2004/4/6 4:57
Re: F.S L18 & L20
From Brisbane
hey FREESTYLER whats your location?
Posted on: 2004/4/6 5:32
