My heater doesn't fit
From Perth Western Australia
Finally managed to get my L20b motor in. In the process, i modified the firewall. now the heater fits about 10 to 20 mm to far away from the firewall.
should i try get another (different) heater?
or should I modify my heater?? ( I would need to move the fan motor and box about 20mm further back)
anyone else had this problem?
Posted on: 2004/7/9 6:06
Re: My heater doesn't fit
From Christchurch NZ
you could just flag it altogether and use 12volt hairdyrers to demist the windscreen.
Posted on: 2004/7/9 6:24
Forced Induction!
the heater hardly does the job, so i doubt a couple hair dryers would.
and i know i got extractors and a cd player, but I'd still hear em no doubt...
Posted on: 2004/7/9 11:10
jaycar make 12volt heaters and also evaperative coolers, the heater can pump out up to 350w of heat, pretty good for $30 and a datto1200. ive got a 60 watt one that keeps my hands warm. if its just 20mm, extend the mounting brackets and screws and seal it up with a hme made alliminuim sheeting box.
Posted on: 2004/7/9 11:52
From Warwick, QLD
Is it legal to use hair dryers as demisters???? I know that might sound stupid but it's the same principle just one doesn't use electricity.
Posted on: 2004/7/9 13:26
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
I was thinking about doing this. but if there is an easier way, why??
And my cd player still has to fit aswell... (can't go without that )
Posted on: 2004/7/10 3:11
its only 20mm, the cd player will still fit.
its a datsun for goodness sake, its not like they were put together with exact tollerences anyway.
it will be fine.
Posted on: 2004/7/10 4:01
actually, the cd player probably isn't the closest thing. the bar for the wipers is really close. now its going to be closer.
I'm making up a plate out of ally that will go over the top of the heater. I'm going to cut a hole in the middle so that its more or less sealed, and extened it to the sides of the heater, so that it serves as a bracket to mount it on aswell. I'll use some longer bolts with spacers for the bottom mounts. It'll fit... it has too!!!!!
Posted on: 2004/7/10 4:45
