12why struts in 1200 sedan
From south australia
i have 120 why struts in my 1200
but theres almost a foot gap between the
top of the wheel and the gard
i have been told that they should fit streight in but is there any thing i am ment to do to get the ride hight down the springs are as hard as a rock and if i cut them i would have to nearly cut them in half
Posted on: 2004/9/16 11:30
Re: 12why struts in 1200 sedan
From WA
i was under the impression that 120Y struts are the same size also...?
are you sure they're not stanza struts?
Posted on: 2004/9/17 3:26
The 120Y STRUT is the same, but not the strut ASSEMBLY. These things will fit, as you have seen, but with diferent results.
If you strip everything from the strut, that is. the spring & the whole shock absorber, then the tube & stub axle part is the same. I do not have the 120Y parts book, so i can not confirm if any, or all, of the shock absorber parts are interchangeable
Rebuild it with your 1200 parts & you have a complete 1200 suspension assembly.
This does NOT apply to the Australian built 120Y's from July '76 as these used a completely diferent disc brake setup.
Posted on: 2004/9/17 3:51
Love your Datsun.
Treat it well.
From Sydney, Australia
Rb20, Did you use the 1200 struts tops and springs or did you install the 120y ones?
Perhaps the springs out of the 120Y are longer and/or harder.zDid you compare them to the 1200 springs before installing them?
If you have the original 1200 springs try switching back to them, they might bring your car back down to earth.
Posted on: 2004/9/17 10:42
Datsun nerd
yeh thanx guys i have only had the car a week ad it is how i baught it so i dont know what the previos owner did ill have to give him a ring and find out its lucky it came with all the original front end to go with it i will be pulling it all out when i give it a respray any way ill work it out then
Posted on: 2004/9/18 3:10
From sydney australia
also,is it using the 120y strut top.if so,go back to the 1200 top,which'll drop it a bit.if there is nothing poking up through the hole in the strut tower,then it's a 120y top.
Posted on: 2004/9/18 13:32
defanetly 120y tops then thanx guys now i know what i gotta do
Posted on: 2004/9/19 0:03
