All this suspension geometry stuff is a bit of a black art to me. I started trying to understand more of it just recently. Until then i followed some words of wisdom from a suspension guru, who told me "You could do alot worse than copy the fastest car in the class". Getting a look under the fastest car isn't always that easy, because chances are he knows what you're up to cause he used to do it himself
scrub radius. its the distance from the centre of the tyre contact patch to where SAI intersects the ground.
'+' scrub radius where the centre of tyre contact patch is outside SAI, '-' where its inside the SAI.
