water temp sender broke
From Feilding, New Zealand
in an attempt to remove the sender uint i broke it in half.
is there an easier way to get it out or does the head have to come off and be sent in.
Posted on: 2005/1/23 20:18
Re: water temp sender broke
From Dunedin, New Zealand
Yeah I had this problem on my old 1200, basically what we ended out doing was to drill the sender out and putting a new one in, as far as I could see there was no alternative to getting it out...
Posted on: 2005/1/24 0:00
From Invercargill, New Zealand
Were you able to remove the threaded part of the sender with the hex head? If so you can use an awl to collapse the copper sender end in on itself and remove it with a pair of needle nose vice grips.
Posted on: 2005/1/24 3:05
From Sydney, Australia
Yes, when refitting the new sender, use a good "non-seize" compound. I like to use "Kopper-Kote" by Jetlube, this is almost essential on exhaust bolts that get really hot.
Posted on: 2005/1/24 6:15
From sydney australia
to get the broken bottom half out,use a tap of the appropriate size,turn it in for a couple of turns,by which time the bottom half should have stopped sticking to the head,then pull it
out.i've had to do this a couple of times,when the 'collapse the sender down & extract with pliers' trick didn't work.i just got a cheap set of
taps & dies from stupid cheap or ripco,& found
the size to fit.much safer for me than drilling.
Posted on: 2005/1/25 10:10
got it got with a bit of sweet.
thanks for the advise now to get the temp below half way on the gauge.
Posted on: 2005/1/25 21:17
