you cant get 'new' a14s anymore i think. a14s bolt into utes without any x-member mods, and if your ute is before 1972 the alternator is on the side of the engine, so some mods are required. a very good condition a14 with all accesories in mint cond is about $500.
then you should think about a different radiator gemini looks good for about $100 and some time and mods.
then theres the usual brake/suspension/ and eventually diff modifications, this vary's too much to give a accurate price. maybe someone can give some advice here?
if you can do most of the work yourself (disconnect wires(and label them!!), rip out the old engine, transport 'new' engine to your house/shop, install engine/radiator, connect wires, fill up with new oils, filters(air, oil fuel), new coolent, radiator hoses etc should cost around $1000 at the ABSOLUTE MOST if you do it yourself
