Skyline Stumpy 5 speed
From Perth W.A
what is the code for the stumpy 5 speed?
i know the A-series is the 60a or 63 a
all i see on mine is L5 on the bellhousing
any help?
Posted on: 2005/2/20 6:17
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: Skyline Stumpy 5 speed
From Sydney, Australia
Posted on: 2005/2/20 11:30
From Perth W.A
Another question now, can you use the stumpy bellhousing or do you need to use a specific one to bolt it to an L18?
Posted on: 2005/2/21 10:50
120y Coupe
From Millgrove Vic OZ
The R30 (stumpy) box is a 71B short extension housing box.
Posted on: 2005/2/21 12:08
Cheers Feral
From Brisbane, Australia
and it will bolt straight up to any L series, 4 or 6cyl. Yes, without angle grinders
Posted on: 2005/2/21 12:47
From sydney australia
look for f5w71 on any build plate of the r30 skyline,if you go to a wrecker.the 5 means 5 speed & the 71 means the two main shafts are
71 mm apart.it'll probably read f5w71b.but,that
w could also be an s,i can't quite remember.i think it has something to do with the gear selection method,internal shifter like a car,or
external connection like a van.
Posted on: 2005/2/22 12:19
Far too much scary Datsun trivia in this thread..
Posted on: 2005/2/22 13:08
From Perth Western Australia
just out of interest, whats the price range on these? I have a dog leg one..
Posted on: 2005/2/22 16:23
there are no dogleg R30 Skyline 5spds. You've got the smaller and weaker Stanza 5spd, which is also a short tail (stumpy) box.
It's not all bad though, the Stanza 5spd has slightly better ratios, whereas the Skyline has a bit of a 'hole' between 2nd to 3rd ratios. Stanza 5spds don't deserve their reputation for being weak. I used one in my L18 1200 for about 5 years, including a couple of years of sprints and hillclimbs, before it cried enough.
A Stanza 5spd is worth about $150 around here, and Skyline 5spds can be picked up for around $250 from wreckers, but I have heard of some absolutely crazy prices being quoted to people. Or you can do what I did and buy a whole MR30 Skyline for $100 and wreck it.
Posted on: 2005/2/23 1:02
