Browsing this Thread:
1 Anonymous Users
Thermo fans, good or bad? |
From Sydney, Australia
What do you guys think of thermo fans- are they better than the regular motor fan, or not? Im running(soon) an A15 in my ute, with the radiator from a sunny.Im thinking big fan, low temp.am i right? also, what if you put a (colour coded)thermo fan onto the louvres on the rocker cover? thats gotta be worth a few more HP.... thanks, Linc.
Posted on: 2000/11/12 7:19
Re: Thermo fans, good or bad? |
From Sydney
Registered Users Contentmaster
I personally think thermo fans are great little items. If you wire them up right. The way i am going to wire mine up (when i get them) is have a switch in the cabin just to control the actual on off - instead of being wired to the ignition. Then have the fans hooked up to a thermometer in the radiator so they can cut in at the operating temp. (or just above? 180degrees is OT i think????anyone???) The stock fan is pretty small anyway and wouldnt be taking much power at all. And u allways know its working. What do u mean by putting a fan onto the rocker cover???? im not quite with it there. My 2 cents + gst Scott Davo
Posted on: 2000/11/13 3:35
