toyota 1ggte, do you think it would fit?
From Springwood NSW, Formerly Tas.
toyota 1ggte (2.0L, inline 6, twin turbo), do you think it would fit in a 120y or 1200, they fit in old corollas. i would probably never do this conversion but it would be interesting if someone did.
Posted on: 2005/5/22 0:42
1978 120y Coupe.
Re: toyota 1ggte, do you think it would fit?
From Mackay
If you did get it to fit you would have to cut alot of the fire wall out as a friend of mine had one in his hilux and it was a tight fit. if you go to one of my picks of the 4agte it's the same motor with 2 cylinders cut off
Posted on: 2005/5/22 1:20
From Sydney, Australia
No.
Posted on: 2005/5/22 1:51
From T'ville
of course it will fit
a little bit of K-Y and anything will go in
would make a great sports sedan
Posted on: 2005/5/22 2:03
From campbelltown (sydney) australia
why put a toyota motor in, when there is a nissan motor of the same setup, ie 2lt turbo twin cam, theres two u can choose from.....
Posted on: 2005/5/22 7:10
* caution, sunglasses must be worn to view my ca18det *
On the subject of of twin turbo'd engines, has anyone tried a VG30ET or VG30ETT in a 1200??
I have a video on my computer of a 1200 coupe on a burnout pad with supposedly a VG30ET in it but its bullsh|t, its just like a L18 or something....
Dave
Posted on: 2005/5/22 11:50
From Melbourne, Australia
c'mon.... go the mighty a15ett!!!!!
if nothing else the exhaust is on the wrong side on a 1ggte, meaning all the exhuast gear is on the same side as your steering and master cylinders etc etc, which would make an extreme tight fit
Posted on: 2005/5/22 12:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
