CA18 Vs CA18DET questions for the experts
From Sydney, Australia
Hey Guys,
Im about to buy a CA18 motor and box and am wanting to know how does it compare to a CA18DET??. Because I always wanted a Turbo im lookin to changing the manifold on the CA18 and adding a turbo... Would this be recommended to do or would you recommend just to buy a CA18DET???
Any comments greatly apreciated.
Thanks
Posted on: 2005/5/30 12:05
Re: CA18 Vs CA18DET questions for the experts
From Warwick, QLD
go with the CA18DET as it has oil squirters in the bores so it helps reduce the heat in the cylinders plus you'd have to get the compression ratio of the CA18 dropeed for a turbo otherwise you'll blow your engine plus the ECU needs changing to suit the turbo, plus then you gotta think about putting water lines to and from the turbo as well as oil lines.
Possible but not fiesable
I hope I've helped
Cheers
Damo
Posted on: 2005/5/30 12:15
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Geeze i didnt think about all that ..... The only reason y i am lookin at this is because it is already fitted to a 1200 and I was looking just to take it out it out it straight into mine.
Thanks mate
Posted on: 2005/5/30 12:26
From sutho shire, NSW, AUS
it would be helpful for you to get the x-member and bolt that onto your car and a CA18det will bolt straight in.
i say definatly go the DET!
Posted on: 2005/5/30 12:58
From California
It would also be great if you filled in you location.
(Yes, I'm the location police.)
Posted on: 2005/5/30 22:16
